Rear Tire Alignment
Rear Tire Alignment
In a previous post I stated that I was getting 6-8K per set of rear tires with mostly highway driving. I believe it was CoarDoc that posted that I should have my toe setting set as close to 0 degrees as possible. I had a new set of tires installed and aligned. The process took nearly 3 hours, because the mechanic said the whenever he'd set the toe the camber would come out, and vice versa. Well after all was said and done my final numbers are as follows:
REAR LEFT
Camber: Actual= -1.4 deg, Before= -0.9 deg
Toe: Actual= 0.26 deg, Before= 0.52 deg
REAR RIGHT
Camber: Actual= -1.5 deg, Before= -2.1 deg
Toe: Actual= 0.24 deg, Before= 0.43 deg
TOTAL TOE: Actual= 0.50 deg, Before= 0.95 deg
THRUST ANGLE: Actual= 0.01 deg, Before= 0.05 deg
Are these numbers representative of what should be expected when you request the toe set to 0 deg?
REAR LEFT
REAR RIGHT
You wouldn't really want the rear toe set to 0 degrees. If you did, then the rear would be squirly under hard braking. However, since you reduced your toe by 1/2, you will get better mileage out of your tires. Do you know what your rear toe is in inches? The OEM setting is .25" total toe in.
No, not sure what the toe is in inches. The sheet here says for the '00 - '03 S2000, the range is 0.16 deg to 0.32 deg.
Isn't there a formula to convert the degrees to inches based on the wheel specs?
