Rear suspension rattle
I am experiencing a loud metallic rear suspension/chassis rattle in my '07 S2K, when hitting any bump in the road. The car has koni's and eibach pro-kits from almost new. I have searched the forum thoroughly, and have not been able to find much on this, except to verify if the bushings in the arms are correctly clocked, which they are. Any input is apprreciated.
is it the right rear that you're hearing the rattling from?
this is just one idea, but you could check your spare tire. and see that the metal plate is fastened tightly. that thing will rattle around otherwise.
if you're sure this isn't the sound you're hearing, then i dunno. good luck!
