Rear suspension making noise
My rear suspension squeaks when I go over speed bumps or any significant dip on the road. It an '04 with about 50K on it. Once the cold weather was gone the noise has significantly decreased, but I can still hear a slight creaking over bumps. Should I be worried about anything here?
mine does the same thing. It just started to happen around 90k miles.
Now I have 100k
I wonder what's causing it. maybe the shock needs to be replaced?
anyone???
Now I have 100k
anyone???
Check your shocks for leaks.
This needs to be in UTH.
This may be totally off, but I had an Acura TSX and I installed rear brace bars. The bars where held up with a brackets and rubber bushings.
I had to continously lubricate the rubber bushings because the brace bar rubbing against the bushing would make an annoying squeeking sound. Hope it helps
