Rear Knuckle, Hub and Bearing Removal/Replacement
Old 06-18-2006, 08:25 AM
  #51
Eluded's Avatar
nobody, excellent documentation.
Old 06-18-2006, 01:07 PM
  #52
gfacter's Avatar
Originally Posted by hecash,Jun 18 2006, 08:16 AM
Assuming that we are talking about an outboard CV joint, I think that it's in the $230 range. You ought to add a boot kit, bands (don't forget to get or borrow a banding tool) and lube totaling another, say, $40 all-in.
Call the Hardtop Guy for a more accurate price.
HardtopGuy.com +1 (216) 749-6989
Ask for Jeff or Joe.
Thanks, already sent a message to Jeff.
Can't I reuse the bands?
I already swapped the inner joints and reused them, just used plyers to get them off and on again. Are these different?
Old 06-18-2006, 02:47 PM
  #53
Former Sponsor
Gernby's Avatar
BTW, I have a pair of low mileage '04 half shafts sitting in my garage if anyone wants to buy them! I bought them last year for $450, and never got around to installing them.
Old 06-18-2006, 02:49 PM
  #54
Former Sponsor
Gernby's Avatar
To clarify, that is $450 for all 4 rear CV joints (inner and outer) and shafts. I will remember which member I bought them from, but they have less than 1K miles on them.
Old 06-21-2006, 03:47 PM
  #55
gfacter's Avatar
Well I just pulled everything off, The drivers side nut was not very tight it didnt need much to loosen, but then became very tight and I had to take the impact wrench to get it off.
The threads are quite mangled on the outboard Joint, I wonder if I can clean the threads up or do I need to replace this also? I looks difficult to remove based in the shop manual, more special tools
Old 06-21-2006, 03:56 PM
  #56
Former Sponsor
Gernby's Avatar
Originally Posted by gernby,Jun 17 2006, 03:20 PM
If you can afford to let the car sit on blocks for a week while you wait for parts, then remove the bearings and races to see if there is any scoring on the spindle. Otherwise, you should go ahead and replace the CV joint too. BTW, all 3 of the bearings I've replaced scored the spindle. Just because the wheel is turning, doesn't mean that the bearing didn't seize.
I'm sorry guys. It has been well over a year since I replaced my last set of bearings, and I sold the car a few months ago. I TOTALLY was wrong about the CV joints needing to be replaced. It was the HUB that was scored and needed to be replaced in all 3 cases. The CV joint only needed to be replaced once when the spindle shaft broke off (after being retorqued by someone else). Sorry.
Considering the cost, I would probably try cleaning the threads on your CV joint with a wire brush (on a drill) before spending $200 on a replacement.
Old 06-21-2006, 04:06 PM
  #57
Nobody's Avatar
Wow--this thread is back from the dead. Haven't had another wheel bearing failure since--? is, though--are all the hub/bearing failures associated with the rear? Should the fronts be replaced every x miles/track days?
Old 12-05-2006, 09:44 PM
  #58
if lookz kill's Avatar
anyone have the part number for a new spindle nut? also how many cotter pins need to be replaced?
anything else need to be replaced when doing the hub/bearing replacement?
Old 12-05-2006, 10:59 PM
  #59
RACER's Avatar
Spindle Nut: 90305-SD4-003 $2.16
Old 04-05-2007, 08:34 AM
  #60
kent-k's Avatar
OP: thanks for the post. i just did a bearing change on a friend's 01 last nite. 2hours, start to finish including cleaning up. i didn't have the honda balljoint separator. i used a two finger puller for the lower balljoint and for the top, i left the arm attached to the knuckle and unbolted it from the chassis.
i pressed out/in the bearings myself so added to the list of tools was a large snap-ring plier for the retainting ring and a slide hammer to pull the hub out of the knuckle.
Quick Reply: Rear Knuckle, Hub and Bearing Removal/Replacement
