Rear Glass Shattered
Originally Posted by negcamber,Aug 22 2008, 11:41 AM
When the dealer put the glass top in they didn't do a proper conversion. The straps on the ribs are configured differently on the glass tops.
im sorry about the breaking, but it seems the conversion done wrong... i helped a friend with conversion.. im trying to think what might be the problem... but i think guys above already pointed out the rib straps
Originally Posted by iball16,Aug 22 2008, 03:11 PM
yeah little nipple looking things that you are supposed to use when you have the tonneau cover on. When I did the conversion from the MY00 top to the glass window top I had to remove the snaps on the back of the roll bars. Even in the DIY it tells you specifically to remove them to prevent top damage.
They did NOT remove the two nipples. It seems to me, now that it's happened again, that catching on them was a possibility. Where would I find reference to removing them?
Does anyone have a car with a factory glass window, and are the nipples present and positioned the same?
I have the glass rear window. There are two plugs, one on each side of the secret compartment door, that can be seen when looking through the rear window.
I'm guessing these plugs cover the nipple holes (pasties)...
Thanks for all the help here on the board. Looks like the nipples were the cuprit. We can see the wear points on the underside near the top of the window where the top was coming down on the nipples (easy to see now that the glass is not there).
On the passenger side it had actually made a hole. Having made the hole, the nipple probably got stuck in it, and the glass shattered when the top was trying to go up but the nipple was preventing that point from going up with it.
