Rear end wiggle
Tire pressures are good, I check them regularly and they're always being adjusted accordingly for auto-x and street driving. I'm convinced that the tires are not the problem, I've had 3 different sets on since buying the car. The tires are currently 225's on the front, 245's on the rear. I've had sizes from 205 to 225 on the front and 225 to 255 on the rear, the car had the same wiggle the whole time.
Maybe NegCamber is onto something with the swapped springs, front to rear. Is there anyway to tell the OEM front springs from the rears?
Subscribing. My car has the same issue, but I just played it off as normal weight transfer issues. It definitely doesn't seem right to me, especially since it's noticeable without significant loading.
Originally Posted by S2000RAT,May 15 2007, 05:27 AM
Sounds to me you need new half shafts
or barings.
My car had same prob.
How many miles do you have and is your car SC?
Rich
or barings.
Rich
![](https://www.s2ki.com/forums/images/s2ki/ranks/member.png)
Hmmm...you have an SC too. Well...one other idea to throw out there. Maybe the diff mounts are dead. They are filled with some kind of greese and I would guess that with enough torque over time they would pop allowing the diff to shift when you get on the power...even just a little.
Still puzzling that the car sits lower at the rear...which is why I thought maybe the springs had been reversed. Not sure how to tell front & rear apart, but I think I've seen a thread or two dedicated to that question. There are painted dots that might give a clue.
Try this, run about 20-30 MPH then down shift gun it. If the wiggle's right away I would say it is the knuckle on the half shaft's is worn out. When I say "knuckle" I mean the part that is the spline cup. It has the rubber boot over it that is full of grease. On the wheel side of the diff.
I had the prob.
Driveshaftshop.com fixed it with the stage 2 axle's
Rich
I had the prob.
Rich
Wow it seems this problem is effecting alot more people than i thought, at first i thought i was the the only one, and the only way i could discribe it is how you are discribing it, a "wiggle" I have narrowed mine down to tire problems....
your problem my be associated with something else, but the symptoms are exactly how you discribed.... I notice it most when I shift over 6k, and over 20 mph
really makes the car feel unstable at high speeds, and it "steps out" on fast gear changes
I've had the same issue you describe on my 2007 since day one. From the research I did on this site, the concensus seemed to point to throttle lift oversteer due to the short wheelbase on the S2000. I saw quite a few postings about this even at low speeds. Mine does it at almost any speed and any rpm when I shift. I check the tire pressure weekly, so I know it's not that. I need to get an alignment to verify that the rear end is in check. Keep us posted if you find a resolution.
This may not apply to the supercharged AP1, but may apply to some of the other AP2s out there.
I had a lot of wiggle under sudden accel such as shifting in straight line and also "stepping out" in turns until I took some of the neg. camber out of the rear.
Here's something to try (but just as a test and not permanently): lower your tire pressure to 28-29 (measured cold) and see if the problem goes away (of course, your handling may be a bit worse so be careful). If the wiggle is better that way, perhaps it went away because lower the tire pressure increased the contact patch with the road. This might suggest a similar remedy to mine - reducing the neg. camber in the rear alignment.
My opinion is that the stock, out of the box setup of this car is too much oriented for the track, especially AP2s, and this is possibly the reason behind so many drivers new to the s2k having spin outs. The good news is that the rear has a wide range of adjustment, so I was able to get to superb, flat, predictable street handling without these problems and with reduced tire wear too.
Agreed with checking tire pressure. Easy to overlook, but my issue was related to my passenger side being at 18psi and my driver at 30psi. Filled up and rode lke newt. I did notice though that when in higher RPM's there is super slight twist when letting off the throttle, but seems completely normal to me.
