Rear End Noise
Rear End Noise
Hopefully someone can answer this for me. I have a noise that is coming from the right rear. I happens when the clutch is let out mostly from a standing stop, but will also happen when shifting into 2nd. We hae looked to see if it eas from the brake pads, the rotor the axle, the cv joint and the wheel bearing. The back of the bearing looks like it might be burned, but there is no play in the wheel. The car has about 25K miles and is a 2001. I am extremely careful with the car, however I do drive it the way it was designed to be driven. We put some antis-seize on the ears of the brake pads and also on the back of the bearing. It seems to have stopped for the time being
what kind of noise is it, a clunking, whine, rubbing? it can be many things so it helps if we know the sound its making. its possible it cold be your cv joint or a bad wheel bearing. try lifting the rear wheel and dont spin it. but try to push on the top or bottom of it. if it moves at all its the bearing.
mine did the same thing.
it could be the axle spindle nuts. Honda updated the torque spec for this very problem.
In my case, the area between the wheel and hub was very dirty, causing some sliding to occur (rolling on the dirt and debris).
i had that problem like that too 3 weeks ago , it was like a loud click (a bit like a computer mouse ) when push/release clutch pedal soft accel.....the dealer had to tight the wheel shaft . he remove both wheel , unscrew the big nut , pull it out a bit then lub the shatf then tight the nut
the only problem is, i have to clean the ****in wheeel once a day ,lol the mags getting dirty evrytime i roll due to grease
i hope for you its that problem ,honda will fix it for free if you under warranty (30 mins job no need new parts)
good luck!!!!
Thanks for the info. I took it to the guy that does all my work and that is what he did. So far the noise is gone and I hope that take care of it. Thanks, JimmyB
My car have the same symptoms.
I'm i Spanish, and i not know what is the "big nut" ?
Any one can post a pic of "the big nut" or explicate me more what part of the car is ??
The picture really help me to identify the part.
Thanks to all
Thanks to all
