View Poll Results: Which rear differential oil is best for 05 S2000 (120K) for daily drive with joy?
Voters: 32. You may not vote on this poll
which rear differential oil do u recommend? I am also going to be doing the tran oil change with Amsoil.
Genuine OEM Honda VTM-4
http://www.amazon.co...asin=B00BYFE6LO
Mobil 1 104361 75W-90 Synthetic Gear Lube
http://www.amazon.co...r/dp/B000ONZXPK
AMSoil (there are so many AMSoil options...which one should fit my car as it is 05, with 120k)
http://www.amsoil.co...duct/gear-lube/
Swepco 201 Gear Oil, 80/90 (used in Porsche)
Honda VTM-4 can't be compatible with the S2000 diff. It has the viscosity comparable to a 20 weight oil, that can't be good as it is way too thin. Cross that off the list.
I'd recommend LE1605 which is an SAE110 fluid , it has worked great for me. Amsoil 75w110 and 75w140 are also good choices. I don't know anything about the other fluid, but I prefer something that is at least a 110 , I try to avoid anything that is 95 or lower, just my preference.
its been covered a bunch of times... lots like the 75w-110 from Amsoil. Depends on applications. search for the previous posts about it. good info. I run 75w-90 Mobil 1 but i might switch to Amsoil next go around. I change every year due to low mileage otherwise i say change every 15k under normal driving.
And there isnt an OEM Honda Diff Fluid fyi
I'd recommend LE1605-- +1.
-- Chuck
-- Chuck
