Rear Defrogger issue
The switch does not light up when pressed in and the window does not defrost.Both softtop and hardtop. The Fuze under the hood looks fine. Do i need a new switch or what to do?
Make sure that the switch is connected to the wiring harness. You might have put some undue pressure and unclipped it 0.0 If anything, you can pull the switch and use a multimeter to test the contacts.
this sounds over simplistic, but you're not getting power and/or a completed circuit. maybe the ground wire has come loose, etc. did you do the installation yourself?
Heh heh, I always call it the "defrogger". Defroster/defogger => defrogger!
s2kdriver80
04-03-2009 07:27 AM
