Rear Control Arm Torque Values
Can someone look up the torque specs for the 4 rear control arm bolts?
I found a post that stated they were all over 90 ft-lbs, but that sounded high, and it also didn't specify which bolts were torqued to what value.
I've got a squeak coming from one of the rear bushings that I think is from me not re-torquing the bushings after installing the suspension (I preloaded the suspension before torquing the botton shock bolt and the tophat bolts). Car has 50k miles on it, and the busings look ok, so I'd be amazed if it's a failing bushing.
Thanks in advance!
Thanks in advance!
on the lower control arm. bolt closest to the middle of the car is (123 nM)90.4 lb/ft. the one closer to the end of the car is (74nM)54 lb/ft
both upper arm bolts (132 nM)97.6 lb/ft as per the manual.
