Rear BJ removal from knuckle
anyone know of a good way to remove the rear lower ball joint out of the knuckle? Im installing some RCA's since the car is lowered
I have a 20 ton press and air tools to use but dont want to destroy parts in the process tools without a good method are useless. Ive searched a good bit on here, google, and the helms thanks guys.
Nope not the toe arm or a bj separator
I'm talking about removing the ball joint from the rear knuckle I got some advice from Scotty and looks like a big c clamp tool is made to push the bj out of the rear knuckle
I had a good shop do mine. I destroyed a ball joint doing my CV cups, and then got new ones from HTG. The shop used a press and replaced it for like $50 in labor.
Yea, I know...paying a shop...bad. Still, I did do the CV cups myself...the only shop that was even willing to do it (all of the others told me that it was a stupid idea) wanted $600 to do it
I have a spare one of those. I beleive.. I pressed mine out and then when I got the ball joint it was already pressed. Fml. If you need it pm me. I took it off the RF but you should be able to use it on the back?
