Rear bearings
Rear bearings
I'm having a hard time finding good hub assemblies for my 01, I don't want cheap but..... I don't want to break the bank either, so if you guys could help me out that would be great,
Thank you.
My s2k sitting behind my shop
Thank you.
honda will sell you the rear bearing/hub assembly for $130 thru majestic. If you need the carrier, Majestic has it for $205/side. Seems reasonable for OEM.
otherwise, you can get an bearing/hub from rock auto for less, but I don't know where else you could get the rear carrier. Maybe a wrecker will have some with questionable history for less.
good luck!
darcy
good luck!
darcy
I have 2 rear hubs with the wheel studs from my 2006 that I replaced at ~125K miles sitting around (axle clicking kept coming back and replaced both bearings/hubs). I can get photos of them to you asap if you're interested.
Doorman hubs aren't bad, been using factory wheel bearings and doorman hubs for almost 5 years without any problems. I ordered them from ebay, it was like $120 for a pair of hubs and bearings. For the record that's the price of just 1 oem hub. You can also get good used spindles, they go for about $130 each.
AlvinHuyN
12-23-2013 09:09 AM
