Rear Ball joint removals
Old 02-26-2004, 06:42 PM
Venomous S's Avatar
Default Rear Ball joint removals
For those that did your rear or ball joint by itself
did you have a problem shocking the ball joints specially in cold weather?
I couldnt get the separator around here...
Old 02-26-2004, 08:12 PM
Billman250's Avatar
Received 1,395 Likes on 836 Posts
Used a tie rod splitter...NOT the fork kind, but the two jaw puller kind. Works perfect, prolly better than the Honda tool.
Old 02-27-2004, 03:14 AM
Venomous S's Avatar
thanks
well hopefully I it wont be much trouble shocking the ball joint out w/o a tool... but if i must i will get the puller kind then...
Old 02-27-2004, 06:48 AM
ItalianBucwheat's Avatar
FYI If your seperating the ball joists to install springs or to remove the diff it is not needed. usta heads up if thats what you doing!
Old 02-27-2004, 07:19 AM
xviper's Avatar
You will not likely separate that joint without a special tool. If you just pound on it with a heavy object, you'll just flatten the end like a "smithy" on his anvil.
You need at least something like this:
As billman already stated, DON'T use a pickle fork.
Old 02-27-2004, 08:48 AM
EFFECT's Avatar
If your pulling out your diff there is no need to pop the ball joints.
Mike
Old 02-27-2004, 02:03 PM
Venomous S's Avatar
Mike
thanks Xviper, ill see if I can get something like that
and EFFECT, how will I clear the half shafts outta the way then ?
Old 02-27-2004, 02:09 PM
EFFECT's Avatar
Just unbolt the 8 bolts holding the rear bushings that hold the diff. then you can push the diff to one side at a time and slide the axles out, its really easy. Took me about 45 min from start to finish.
Mike
Old 02-27-2004, 02:12 PM
xviper's Avatar
OK, beat me to it.
Old 02-27-2004, 03:20 PM
Venomous S's Avatar
ok very nice, thanks Effect and Xviper
I always prepare myself w/ the manual and thats what it said to do and plus I havent been under my car for a while and didnt know if I could make it without removing the ball joints
But this is good, ill save about a 100 bucks on tools
Quick Reply: Rear Ball joint removals
