rear axle pops every time i take off and shift
2004
67k miles
tein s tech.
oem rims and sizes.
ive had the springs on for about 8k miles now.
my alignment can only be adjusted to -2.1 camber in the rear due to ptuning telling me i have seized bolts. but another shop telling me it cant be adjusted.
every time i take off and shift or sometimes when i brake i hear a pop from my rear. its only gotten worse over the past 2k miles. no vibrations what so ever. it first started happening only when i reversed and then again when i moves forward slowly. now its all the time in any direction
i already backed off my axle nuts and retorqued them to 220, didnt fix the problom
help!!
67k miles
tein s tech.
oem rims and sizes.
help!!
Originally Posted by Jack_in_the_Box,May 24 2009, 07:40 PM
torque down your axle nuts to 250.
![](https://www.s2ki.com/forums/images/s2ki/ranks/member.png)
Not 250...220.
But if you've already done that, you may need to grease the axle splines. Give that a shot. And it'll give you another chance to retorque to 220ft-lb. Don't forget to put a dab of grease on the back of the nut that rests against the hub.
Originally Posted by negcamber,May 24 2009, 07:48 PM
Not 250...220.
Just a moly grease is fine. You'll need to pop the lower ball joint...so you'd need a tool for that. Try not to use a pickle fork...you run the risk of damaging the rubber boot which will mean replacing the ball joint at some point.
solitarycheese
05-26-2017 11:10 AM
Chris_Lum
10-05-2010 10:18 AM
