Rear axle nut: ?what size socket and ? undo locking tab
what size socket is the lock nut on the rear axle?
also, what's the correct way to lift the locking tab
is the correct torque 181 ft-lb.....i've seen 225 ft-lb in a post.
Originally posted by vapors2k
wasn't there some sort of service bulletien on tighting the axle nut to a higher torque spec?
Please post socket size and part number when you get a chance.
Honda has its own grease (urea type) that is recommended for its clutch replacement; it probably can be used in this application as well.
