Re-greased my shifter
Old 10-17-2013, 05:44 PM
mikey430's Avatar
Originally Posted by INDYMAC
Just keep driving with the regreased shifter. It will continue to get better. The notchiness is ok. It will help prevent money shifts by being able to feel the gears. I found the shifter grease to virtually eliminate the 1-2 crunch. How about you?
I have noticed it getting smoother after driving around the pass few days. I also decided to disassemble the shifter again n use the little bit of grease I had left bc for some reason after greasing it the first time... Pushing the stick in to select reverse felt had n I really had to push hard to get the shifter to go down. Anyway now that I used the last of the grease it's feels a lot better. I'll probably change the clutch fluid soon as well. Yes it does I no longer feel like I'm arm wrestling with my car to shift.
EchoOfSilence
09-19-2023 01:47 PM
slowpokeS2K
09-21-2010 09:30 AM
DrCloud
07-29-2005 02:31 PM
Squeezer
01-16-2004 03:47 AM
Quick Reply: Re-greased my shifter
