Rattling noise (yes I have googled)
So recently my car has been making this weird noise. When I get close to 3k rpms and higher theres a rattling coming from the engine like a screw bouncing around.. it gets louder the higher rpms i get. The noise can only be heard from inside the car not from outside. I was thinking it could be the heat shield, but not too sure.. If anyone has any suggestions that would be great.. thank you in advance
When I first got my car, I had the same problem. I would hear this rattle noise at 4k+ ...drove me nuts. I thought it was my heat shield/cat nuts being loose so I tighten those down but didn't help. I later swapped my POS exhaust because the pipes had cracks, solved my problem.
I assume if you can't hear it when parked, it is nothing that can damage your car.
