is rattle sound after engine turned off normal?
hi, i just got a civic about 2 months ago. now i know that i've been under 50mph and under 5k of rev during my period of engine break in. but lately i've been getting rattling sound after my engine has been turned off. i was wondering if this is normal. if it is not then i should take it to dealer and have them fix it rite? please help me!!!!
I posted about this awhile back and was informed that it is normal. I sure hope its normal because it hasn't stopped.
Mine comes from (what sounds like) the right-mid section of the engine bay. Though I can hear it from the back too, might be something with the exhaust.
But anyways yeah. People have told me that this is totally normal. My fiance's Nissian Xterra does the same thing
Jaykkub
Jaykkub
[QUOTE]Originally posted by Jaykkub
[B]I posted about this awhile back and was informed that it is normal. I sure hope its normal because it hasn't stopped.
it is absolutely normal.
My 02 has about 1000 miles and it does that as well.
It think that it is due to the fact that the catalytic converter cools off quite fast when you turn off the engine, which causes some clicketing noises.
It use to happen in my older Porsche 968 as well.
Nothing to worry about. It usually happen after a spirited drive.
Cheers
Cheers
If it lasts for a few minutes, it's the sound of the exhaust pipes shrinking as they cool. I believe the noise comes from the movement of the joints. You wouldn't normaly notice the noise, unless you just got car that makes you stand and admire it when your done driving it.
The noise that I hear can be heard when the car is idle too. I have the comptech exhaust, so when the car is moving nothing else can be heard
But after talking to some people it sounds like this is normal. Heh, I sure hope its normal or I'm screwed
Jaykkub
Jaykkub
my 01 with 5k miles has noise once the car is shut down. i noticed if i dont drive the car very hard, the noise is not as loud.
if i drive the car rough, then the sound is a bit louder. sounds like it is comming from the cat converter.
at first i thought i was using bad gas and the car is pinging.
btw: has anyone tried ontane booster on their car yet. do you guys recomment an octaine booster every fill up.
Jaykkub
Jaykkub
Either your exhaust is loose (check *all* the bolts) or someone lost a bolt when they were working in there. Bolts like to sneak under the heat shield.
Cheers,
Ben
