Rattle at A/C Heater Climate Control Panel
Hey all, searched around quite a bit and didn't see anything. 2005 w/ 148k miles. Ever since I replaced my motor mounts (which were both essentially separated), the increased vibrations after reintroducing the engine to the chassis have led to a serious hunt for rattles. The latest oone seems to be coming from the panel that has the climate controls on it. I can consistently get it to rattle while driving around 3.5k rpms, and when i press in on the panel between the knobs the rattle greatly diminishes, sometimes goes away completely, until I stop pushing on it. The panel seems secure and doesn't move around, so i'm not sure if it's the panel itself or something behind it.
Ahead of pulling the whole cluster off, I thought I do a quick check to see if anyone else has experienced this and fixed it. Thanks all.
Did you tighten the motor mount bolts like it specifies in the manual? You gotta tighten the bolts in order.
also are they oem mounts or aftermarket? If aftermarket mounts they tend to vibrate more.
Sounds like I'm pulling the panel soon...
Well, turns out it was me over-complicating things. The Recirc Air button is just barely loose enough to rattle at just the right RPM. It doesn't feel loose, and pressing on the panel is just enough to dampen it out. I'm going to try and fit a bit of electrical tape on edge to stop it without actually binding up the button. Oh well, at least it's minor. /thread
