Random Misfired issue
hi guys, my frd's 03 ap1 got random misfired issue recently. At first, he replaced all his plugs and we all thought the issue was sloved. Last week, the light was back again. Same code and we decided to erase the light and see if it gonna come back on again. It didn't. We all thought that should be computer error or misread. Today, the light is back again. What could be the problem? The car currently has 66k miles.
we did some research online. what we think could be the issue might down to either value adjustment or the coil.
Let me know what you guys think, anything would help.
Thanks
Thanks
If u aren't experienced with doing motor work I would only take it to a well known S2000 specialist.
Thanks
Thanks
Same exact thing happened to me, and a 30 dollar case of injector cleaner nipped it in the bud.
After you run two tanks of treated gas through, if your CEL is still on, do a manual reset. If the code appears immediately again, it's probably not gummed injectors, or yours are so bad that they need to be removed and cleaned. A guy does it on here for 60 bucks.
It's worth a shot. Cheap fix if that's all it is.
Gas these days can be pretty bad. I always stick with Chevron or 76. Preferably no ethanol.
