Random Misfire I can't figure out
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
02 Honda S2000 w/ 45k on the dial.
I downshifted to 4th from 6th on the highway Sunday, laid into the gas, and the car started to misfire. Ran fine before this...
Pulled the CEL.
1,3,4 were misfiring.
Reset.
4 was misfiring
Reset
1,2,4 misfiring.
I borrowed my friend's coilpacks and replaced them one at a time. Didn't matter - it still misfired. Suggestions? It's misfiring bad enough that it's popping in the exhaust loudly. Kind of like an RX7
Pulled the CEL.
Reset.
4 was misfiring
Reset
1,2,4 misfiring.
![redface.gif](https://www.s2ki.com/forums/images/smilies/redface.gif)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-3yr.png)
Have u read the FAQ yet?
https://www.s2ki.com/forums/index.php?showtopic=659930
Mine never came back after changing the injectors, cleaning the IAC valve, and changing spark plugs. You might even need a valve adjustment and or compression test.
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
Popping on idle leads me to believe it's the injectors. Had to replace mine after doing all the steps.
https://www.s2ki.com/forums/index.php?showt...&#entry15658384
sounds like you need to get a compression leakdown test and check the valves. Just got done fixing this problem with my S had almost no compression at all in cylinder 3 and it pulled codes for a bunch of random misfires too. Hope your valves aren't bent!
