Ran over multi-ball hitch
Old 10-16-2010, 11:36 AM
NoRegrets78's Avatar
Default Ran over multi-ball hitch
Hey guys, just wondering if anyone could tell me if this is something I should be worried about.
Dark and raining, didn't see the black painted multi ball trailer hitch lost in the road until it was too late to do anything but straddle it.
Pic of offender, but the one I hit had black balls (heh):
Damage:
The car drives exactly the same as it did before. Steering wheel dead straight.
Is this something I should be worried about? Should I replace the cross member?
Thanks in advance.
Old 10-16-2010, 11:43 AM
zeroptzero's Avatar
Received 3,543 Likes on 2,545 Posts
your lucky it hit those spots, it might have cracked the oil pan if it was a few inches the other way. I don't think the dent on the lower bar will affect the stiffness of the bar, but if you happen to find a cheap used one someday you might want to replace it so it doesn't look dented.
Old 10-16-2010, 12:11 PM
Saki GT's Avatar
Yeah, I think you got lucky it hit the durable and shielded parts and didn't tear a hole in your pan or cat!
Old 10-16-2010, 05:44 PM
I know I'm lucky it wasn't worse. It sounded and felt awful! The front two arrows I'm not worried about as it is the jack point but what is the proper name for the cross brace? Trying to look it up online to buy one.
Old 10-16-2010, 06:54 PM
spook's Avatar
I wouldn't worry about the brace. You're not going to feel a difference.
Old 10-16-2010, 08:11 PM
chubbychu's Avatar
wow! that was a close call!
Old 10-17-2010, 01:03 AM
S2KPUDDYDAD's Avatar
man, that must have made some horable sounds hitting the under side of your car
Old 10-17-2010, 07:02 AM
R1_Pilot's Avatar
Majestic sells it for $46 ... It's under crossbrace I believe.
J
Old 10-17-2010, 11:02 AM
J
Thanks boss!
Old 10-17-2010, 11:15 AM
Got the proper name. Engine Mounting Stiffener.
If I take the name as purpose, there should be no reason I couldn't just leave it alone, but I'll probably replace since it's a relatively cheap part. Have to consult the Helms Manual to see if removing it is as simple as unbolting, replacing or does something need to be braced as I remove it.
Quick Reply: Ran over multi-ball hitch
