Radiator leak
#21
Very nice! You may need to do some slight modification to the intake but nothing major. The Koyo doesn't come with foam like the OEM one does. I've seen some people just leave the gap and others I guess end up getting a piece of foam from Home Depot and cutting it to fit. Not sure if there's a write up on it or not.
#22
I replaced with an OEM radiator when mine cracked. But it was based upon timing. I had an autox event coming up in 3 days and had to go with what I could get quickly to make it. Unfortunately that meant not being able to wait for even Majestic so I paid too much through the local dealership to get one. I may have just gone with the Koyo otherwise as it is pretty widely used.
#23
Yep I installed it last night. Picked up some foam from Home Depot.The fan mounting bolt does rub against the intake so I got some foam (compressed) and put it in between. I also picked up a thermostat intending to change it but couldn’t reach the bolts on the thermostat housing haha. Hardest part of the install was removing the lower radiator hose from the old radiator
cs2k04
09-12-2009 12:20 PM
