Quick question for window regulator, window switch
Hello All,
I have a small problem, the passenger window does not go up. I made the mistake of assuming it was the motor and I order one =) Of course I connect it to test it and the only thing that happened is that it went down and it wont go up.
I tested the new and the old engine with 12 volts and both go up and down.
The switch is sending -12 volts, no matter what position it is. At this time I think the problem is the switch but I would rather confirm than buying a second part.
Do you guys agree it is the switch?
Tona
Tona
bump, I got the passenger switch and I got the same result.
I looked at this thread but he did not say what was the solution:
https://www.s2ki.com/s2000/topic/947...ow-wont-go-up/
I checked fuses 17, 18 and 8 and they all look good.
Should i just get the master switch too?
Hello All,
Tona
Tona
jammer2209
03-15-2011 12:49 AM
