quick question on engine oil
I use Amsoil 5W30 in the colder months and 10W30 in the hottest 3 months. Generally speaking - there shouldn't be a problem using 5W30 - however, keep in mind not all oils are equal.
Depending on the brand of 5W30 you used - a lesser oil that's already outside of the factory recommendation may not stand up to what you consider "normal" use.
If you're using Amsoil, Redline, M1 Extended Performance (NOT standard M1), Pennzoil Platinum, Delvac, Elf, and a couple of other Euro synthetics - you won't have a problem.
I don't recommend pushing standard M1 or any of the commonly available mineral based oils though. You may run into consumption problems.
I actually get better mileage running Amsoil 5W30.
slipstream444 Posted on Sep 30 2007, 08:51 PM
Serious, oil questions like these have been answered many, many times.
On forums with some moderation posts like these would not live very long.
The OP would be kindly taken by the hand and led towards the FAQ.
But here, we get answers like
Without any explanation WHY 5W-30 is wrong.
The OP gets the advise to
That by itself is good advise but in this topic people may think a 5W-30 is bad for your engine and you need to be gentle with a cold engine when you use it....
However..
Blizz actually uses the info he/she's given and reaches the proper conclusion:
As many have.
Long time ago.
When the wheel was invented
Long story short:
I was trying to be funny.
The picture was not "aimed" at you slipstream444
Next oil change, use the right oil.
Also, be gental on the car when it's cold.
However..
so in reality this is better for cold starts. Hmm Interesting. possibly a permanent change then.
Long time ago.
Long story short:
S2kracka Posted on Sep 30 2007, 11:24 PM
Is that because you have a Berlina?
If so, then it makes perfect sense.
Otherwise...
I wouldn't use 5W-30 in anything but the coldest climates in the S2k.
Otherwise...
If we just dumped the thread then we wouldn't be solving much - the OP would still be and post again thinking that something magical must have happened and the thread vanished.
[QUOTE]On forums with some moderation
Okay....
NVMY4N Posted on Oct 1 2007, 03:17 AM
And I agree with your frustration of n00bs posting these questions.
Asked without taking the effort to search or read the FAQ.
But I'm your man when a nice oil debate is started.
[QUOTE]If we just dumped the thread then we wouldn't be solving much - the OP would still be
I have come to find out that anything that has to do with oil on this forum can turn into a very heated debate.
Some members are now swearing by 0w20, whereas I will go with a 20w40 in the warmer months here in GA.
My input is just read around, take into consderation where you live(climate), and how hard you drive your car, and take that into consideration when choosing your oil.
5w30 will be fine.
5w30 will be fine.
Its more that these questions are asked too much, noob or not.
Not dump it => lock it with the remark to read the FAQ and/or do a search.
[QUOTE=SpitfireS]
I'm no mod
stockae92
01-31-2003 12:50 PM
