quick krankvents install question
Install with both arrows pointing away.
To double-check before the install though, blow (with your mouth) into each side of the KrankVent, one way should flow freely, and the other should engage the check-valve. You want the side that flows freely to be installed so that air inside the crank case can escape, but no air can get back in.
