Quick exhaust question
Old 08-04-2004, 04:18 AM
GodoftheBOLP's Avatar
Default Quick exhaust question
Okay so my invidia finally came i got it yesterday after i get off work, I'm gonna venture home in this god damn rain and pull it in the garage and install. Heres my Q:
After removing the stock exhaust should i bolt the two peices of the invidia toghet before installing or install them both 1 at a time?
Thx, just wanna make the install as quick and easy as possible
Old 08-04-2004, 05:07 AM
gsp
gsp's Avatar
I hung them first then bolted.
Old 08-04-2004, 05:48 AM
alright, thanks,
Old 08-04-2004, 06:52 AM
xviper's Avatar
When installing exhaust systems, always "temporarily" bolt stuff in place, do a final check and alignment, THEN do the final torquing of all bolts. It's a lot easier to install and align if everything is loose.
Old 08-04-2004, 07:22 AM
So your saying bolt the two together but only tight enough so that I can still adjust it after installing it on the hangers etc...?
Old 08-04-2004, 08:30 AM
xviper's Avatar
Nope. Since all the pieces will start out loosely connected to each other anyway, it really doesn't matter. Do what is most convenient for you. Personally, I'd hang them up in small pieces since this is easier to work with than trying to get one big piece up at once. Hand tighten everything, move back, have a good look, make any adjustments necessary, then lock it all down.
Old 08-04-2004, 08:34 AM
Ahh, great gotcha, Thx a ton... Wish me luck its going on today... wish it would stop effing raining though my cars getting soaked
Old 08-04-2004, 08:43 AM
xviper's Avatar
Don't forget to spray all your old bolts with Liquid Wrench (or WD-40) and the rubber hangers with Silicone spray. Those 3 cat bolts, in particular will need an extra shot and a few minutes to work in. Don't be surprised to hear a lot of gawd awful squeaking when you turn them things, although you may be lucky. If they squeak real bad, turn a bit, spray a bit more, turn a bit more. You don't want to have a busted bolt with your car hanging in the air and no spare to put in.
Old 08-04-2004, 09:09 AM
so soak the bolts before i remove the stock and before i bolt them back in correct??
Old 08-04-2004, 10:42 AM
xviper's Avatar
Before is fine. If they were really hard to get off, then do it again after so they don't cross thread going back on.
Quick Reply: Quick exhaust question
