Quick brake pad change query
Sponsor
![](https://www.s2ki.com/forums/images/s2ki/ranks/sponsor.png)
I'm assuming my pads are dead because my brakes are squealing even when I'm not on the brakes.
1. Should I change both front and rear brake pads at the same time? The fronts are the ones making noise.
2. Do I need to bleed the brakes? My brakes aren't soft or mushy.
3. I have 60k miles. Do I need to have the caliper measured to see if it needs to be replaced?
Thanks s2ki.
Thanks s2ki.
__________________
![](http://www.JS2k.com/images/newsig.jpg)
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
_________
1. Fronts and back wear at different rates. You can change them base on condition or convenience. I would do them on condition just because I don't mind working on the car often, unless they both need it soon.
2. How old is the fluid? You may need to bleed a little to get the new thicker pads to fit. Might want to consider a full flush if you haven't done one already.
3. I think you mean the rotor, should be fine at 60K.
Thanks s2ki.
Thanks s2ki.
2. With 60k miles on the ODO, it would be a very good idea.
3. I think you ment rotors. Getting them checked and turned is also very inexpensive, but only necessary if they are scraped. Calipers should be fine. Just check the piston seals.
Sponsor
![egads.gif](https://www.s2ki.com/forums/images/smilies/egads.gif)
![tongue.gif](https://www.s2ki.com/forums/images/smilies/tongue.gif)
Thanks for the quick responses guys! *bows*
__________________
_________
_________
not to mention is you don't change the rears but change the front you upset the braking balance of the car.... bad..... thats a perfomance issue as well as a safety issue....
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
In the case of the OP, I would only change out the fronts tho it wouldn't hurt to look at the rears just to see how much is really left.
![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
s2000maniac
09-24-2012 01:42 PM
