Questions about turbos
Old 02-11-2003, 08:11 PM
Anthonymv's Avatar
Pinky, what boost level are you speaking about? I believe 6psi and no hard launches (because I never drop the clutch) will be fine for the car. Up to .5 bar seems to be fine on the engine and drivetrain if not drag raced so since I dont drag race I do not think I iwll have too many problems. Just curious as to what you were speaking in reference to. thanks, Anthony
Old 02-13-2003, 11:33 AM
Kiki's Avatar
Thanks, everyone, for all the info!
Old 02-13-2003, 11:42 AM
Pinky's Avatar
[QUOTE]Originally posted by Anthonymv
[B]Pinky, what boost level are you speaking about?
Old 02-13-2003, 12:53 PM
Anthonymv's Avatar
you are right. I will have it set at 6psi and I never drop my clutch. I drive agressively but never launch the car. I will get a new clutch for sure but am hoping that my rear end hold out until I have enough money to buy a J's 4.44 and a new diff from Kaaz. -Anthony
Old 05-16-2003, 02:44 PM
SuzukaS2K's Avatar
Well, if I have the builted motor with lower compression.......can I still use my stock ECU w/ e-manage? or do I need standalone system?
Old 05-16-2003, 03:05 PM
BlackS2000Turbo's Avatar
Honestly? You can "rig" it to work but it's not recommended. If you have the means you really should get bigger injectors and a standalone. Just my opinion though.
Old 05-16-2003, 04:28 PM
Anthonymv's Avatar
for a point a reference, as of now, not saying it will not happen, but cjb with 400+ to the wheels has not had a problem with the rear yet. He doesn't drag the car at all though. So I assume that if driven agressively, but not like you don't own it, the rear should hold up long enough (maybe even really long) to get a new Kaaz diff, comptech bearings ect. I agree with blackS2000Turbo in regards to the ecu and injectors.
chad86
05-29-2011 04:09 AM
sfrost2287
03-18-2011 04:27 PM
blackey
07-31-2007 05:19 PM
s2guru
03-26-2007 09:12 PM
mdigrappa
04-03-2003 07:13 PM
Quick Reply: Questions about turbos
