Questions about break-in & oil grade
I'm a new S2000 owner (bought a new 2006 Sunday), and I'm trying to get a handle on some maintenance issues. I've been reading the FAQ articles, etc., and have questions about break-in, oil, trans & diff fluids, etc.
Break-in: I'm hearing it's best to stay out of the VTEC until you've put 600 miles on it, though some disagree. I plan to honor this. So far I've only hit full throttle a few times, for half a second in 1st - 3rd, rpm < 5500. I understand that the original oil fill is a special break-in oil. Acording to Road Rage, this can be approximated on subsequent oil changes with a bottle of Valvoline MaxLive Engine Protector. Some have said break-in isn't complete until 10K miles. Really?
Up to how many miles is the MLEP helpful?
Oil grade: Lots of discussion and a variety of opinions here. OM specifies 5W-30. Some have suggested synthetics are a waste unless you plan to use extended change intervals, like once/year. I usually change oil in our cars twice a year, which at our driving rate works out to ~ 3-4K/change. I always put on a new oil filter, but have been re-using the washers. I'm going to use the Honda 1500-PCX-004, and I'll get some washers.
I guess my main question here is, 5W-30 or 10W-30? My area has moderate temperatures.
stick with 10w30. you should be fine with that. follow the maintenance schedule and you'll be fine as well. it is not yet confirmed specifically what honda puts into the factory fill, though from what we've seen it's high in moly count to help breakin.
regardless, don't go to synthetic until 7500-10,000 miles. and when you change out the factory oil, use a conventional like mobil drive clean (that's what honda oil is rebadged as)
personally, I use havoline GF4 conventional oil, and change it every 5k. works fantastic, and my first UOA came back great.
Your owner's manual should be your guide. Most of your questions are answered in there.
You shouldn't be "hearing" this. You should be reading this in your owner's manual. Do you want to believe what Honda has printed in a manual which they provided you or someone who nothing to do with Honda or your car telling you, "Drive the crap out of your car from the second you leave the dealer. Your car will love you for it." Who holds the warranty on your car? Honda or ............... ???????
Are you sure? Mine says 5W40 or 10W30. Has something changed?
Again, follow your owner's manual. It's based on mileage or time, whichever comes first.
OM specifies 5W-30
I've got an 06 also. In reading the owner's manual there does not appear to be a formal schedule per se to follow (ie change motor oil every 3K). As far as I can tell the only instructions regarding changing engine oil is to follow the maintenance minder/oil life indicator percentage display on your odometer and dash. It does say however, if you do not get a maintenance reminder to change your engine oil once a year.
If there is a maint. schedule in the manual could someone instruct me where it is. thanks
Honda recommends 10W-30 according to the owner's manual.
Originally Posted by Wisconsin S2k,Mar 19 2006, 07:22 AM
yeah, i can't imagine they dont give you a schedule for diff, tranny, etc
Originally Posted by Harpoon,Mar 19 2006, 04:01 PM
It's nuts, but that's exactly the situation with my wife's '05 Odyssey - nothing in either the owner's manual or the Helms manual. You're totally dependent on the computer, or the dealership.
