question reguarding Hesitation w/ vortech?
Old 03-13-2003, 01:31 PM
spapdx's Avatar
Default question reguarding Hesitation w/ vortech?
I have been noticing that when I am driving at low rpm's, every once in a while (usually 3rd gear below 3500 rpm) if I am driving at a constant rpm and let off the gas just very slightly the car will kinda hesitate and almost kinda sputter. When it startes to do that if I leave the car at the same rpm it will stop doing it within a few seconds, or if I give it gas it goes away right away. Any ideas on why it does this?? It is really hard to explain. Anyone else notice anything like this? Thanks!
Old 03-13-2003, 05:05 PM
xviper's Avatar
Mine did this exact same thing and does it every once in a while but not lately, though. I think it's because right at about 3500 is where there is a transition into "significant" boost (or departing from boost if you're dropping rpm's). This might cause the MAP sensor a bit of confusion just momentarily at certain times when the MAP electronics (from Vortech) doesn't quite do its thing fast enough. I believe my car has "learned" what's going on and it hasn't done it for quite some time now. I wasn't worried about it as it is quite understandable with the addition of boost that some things will give the ECU the occasional "brain fart".
Old 03-13-2003, 06:49 PM
SGATE21's Avatar
I'm having the same thing happening too
Old 03-13-2003, 08:35 PM
Steve@Evolution's Avatar
It happens quite often on forced induced Honda running peggy back electronics. Have you driven a turbo charged B series with all the add-on electronic assisting the poor ECU from seeing boost and controlling the larger than stock injectors? Vortech did a great job hiding it compare to some " things" I have test drove.
Old 03-13-2003, 10:29 PM
xviper's Avatar
[QUOTE]Originally posted by Hybrid
[B]It happens quite often on forced induced Honda running peggy back electronics.
Old 03-14-2003, 04:18 AM
BryanS2k's Avatar
I'd put it on the dyno and see, it might be running rich in the lower rpm band.
bryan
Old 03-14-2003, 05:30 AM
Rox
Rox's Avatar
Same slight problem with mine, however one time it started doing it badly and I found out my belt was loose causing the engine to stubble.
Old 03-14-2003, 08:29 AM
spapdx's Avatar
Cool thanx guys
I had never heard anything about this so I was kinda worried. Which belt was loose ROX?? The supercharger belt or your alternator/ac/water pump belt??
Old 03-15-2003, 08:36 AM
VTECPHIL#6829's Avatar
Me too. I notice it once in a while when I first accelerate, a slight hestitation or stumble. I know I am running rich and can't do anything about it until my harness arrives for the VAFC. PT
Old 03-15-2003, 11:35 AM
spapdx's Avatar
Thats good to know im not alone on this one....I just got my vafc so I will put it in soon and get it on the dyno and see if I can get rid of it
Quick Reply: question reguarding Hesitation w/ vortech?
