Question in regards to oil leak
Originally Posted by Slows2k,Aug 12 2007, 02:26 PM
I'd clean everything off 1st, with non-cholinated brake cleaner. Make sure the entire surface is oil free. Then get some spray on foot powder and spray every seam from the girdle and timing chain case. Start up the engine and look for where to oil starts to show 1st on the powder.
I'd be more suspicious of the oil feed hose for the SC, the VTEC solenoid bolts being loose or broken or the timing chain case seal being the cause than the girdle.
We did do a thorough cleaning with brake cleaner prior to doing the test drive and the area that first showed oil was that seal above the girdle.
I believe my next step is just going to be finding a shop to undertake the removing and repairing the girdle and oil pan, if that requires to remove the engine so be, but I will let that be there call. Most important thing is that it gets done right. This just seems to be a continueing saga with the incompetence of South Florida Performance, the installers of the s/c. Funny how they are no longer in business. Live and learn!!
Thanks for the help guys!
Deiger
[QUOTE=DEIGER,Aug 12 2007, 04:37 PM]I believe my next step is just going to be finding a shop to undertake the removing and repairing the girdle and oil pan, if that requires to remove the engine so be, but I will let that be their call.
Originally Posted by RACER,Aug 12 2007, 06:48 PM
If the engine has to be removed to perform this procedure, may as well install a brand new clutch.
Has anybody heard anything good or bad about that new S2ki sponsor's shop in Virginia. I will see if I can find their link.
Deiger
Here is the link:
https://www.s2ki.com/forums/index.php?showtopic=515181
Any feedback from anyone.
Deiger
Deiger
cheddaboy
10-22-2014 12:17 PM
