Question regarding the OEM oil filter...
Old 01-12-2009, 02:32 PM
Wiggum's Avatar
Default Question regarding the OEM oil filter...
Does anyone know the measurements/diameter of the OEM Honda filter? I don't want to pay $25 for the Honda tool, so I picked up a variety pack from Harbor Freight for $5 which has a few different sizes. I need to make sure one is going to fit before I open the package, and don't have a spare filter here. Thanks for the help guys...
Old 01-12-2009, 02:46 PM
SheDrivesIt's Avatar
Go measure yours.
Old 01-12-2009, 03:34 PM
vincewchan's Avatar
If I knew the size I would tell you, but all I can say is you can always call your local Honda dealer and ask
Old 01-12-2009, 03:36 PM
Wiggum's Avatar
I got my car preowned and it's a NAPA filter. Anyone?
Old 01-12-2009, 03:45 PM
vincewchan's Avatar
^ Call Honda and ask.
Old 01-12-2009, 04:41 PM
Wiggum's Avatar
My NAPA filter is 80mm. I'm thinking they may be the same. I'm guessing someone on here has a filter from a local parts store that has a number written on it.
Old 01-12-2009, 04:50 PM
Vanishing Point's Avatar
PCX-004 filter dimensions.
height- 3.25"
radius- 3.25"
diameter-6.50"
* measurements taken with plastic cover on filter.
Old 01-12-2009, 05:42 PM
Wiggum's Avatar
Thank for the help.
I wondering if the cap is just a hair bigger. One of the filter wrenches that came with the set was 80mm, which is 3.15 inches. I'm thinking this is going work.
Thanks again.
Old 01-13-2009, 10:50 AM
SpitfireS's Avatar
Diameter (d) = 2x radius ( r )
Circumference = 2*Pi*r or Pi*d
Old 01-13-2009, 11:57 AM
INTJ's Avatar
I had no luck with the cap end wrenches. I had several small ones from other cars and I had to go for one of the claw design (giant pliers). The flats and diameter varied significantly from my factory and the gold I used in a pinch (and the store frams for comparison). This claw wrench is really the only way to take off the filters if they are put on right (tight to spec).
Quick Reply: Question regarding the OEM oil filter...
