Question regarding max speed in different gears
Originally Posted by sychiu,Oct 14 2010, 09:56 AM
Please help me out here.
Did you take it to the rev limiter and hold it there until the speed stabilized? Because there's a delay in the update of the speedo, and if you simply accelerated then shifted near redline you likely weren't as close to the rev limiter as you thought you were.
Also, if somebody simply installed a 4.30 rear gear without doing anything else, the speedo would show the exact same thing as before the install - it'd simply be wrong for the actual speed of the car. (The speed sensor is in the transmission, before the final drive gear.) If they did something to then correct the speedo readout, there'd be an aftermarket box somewhere under the dash to modify the speedo signals. (For example, with this "Yellow Box" from Rick's. http://www.ricks2k.com/products/yellowbox.php)
I suspect your issue is simply a false perception on your part. My first guess is that there's neither anything wrong, nor any mods to affect your gearing. I could be wrong, but...
