QUESTION: Cleaning Throttle Body
Question on cleaning your TB. It may be posted somewhere, however I was unable to find it.
How often do you clean and change the gasket on your S2000? Also, any tips on removing the gasket would be greatly appreciated.
After seeing mine, I will be checking it more often!
Thank you!
Thank you!
Doing general spring maintenance. Did a “Billman” valve adjustment and amazing!
At 45k miles I thought it would be prudent to check air filter and TB. I was surprised how dirty the TB was.
There are instructions in the service manual for cleaning the TB , however no interval listed. After doing the re-learn procedure I took it for a night drive last evening.
Thanks for the reply.
I think you should clean your IACV with brake cleaner spray; you can do it with out removing it [Not ideal] ; if you have 10mm it's 3 bolts and just use a q tip to get inside and ensure all the gunk gets out.
See Jason's Videos
See Jason's Videos
Someone correct me if I’m wrong, however I do not think MY06 has an IACV.
The TB was not difficult removing and reinstalling, maybe 15-20 minutes each. The cleaning was a PITA! According to Honda you do not spray directly into the TB, wipe off the carbon with a paper towel soaked with cleaner and do not clean the bearing area.
The gasket was quite difficult to remove without scaring the surface and took me 2 1/2 hours to remove it and clean the carbon. Honda does not elaborate on how to remove the gasket. I took my time and patience.
If anyone knows of an easy way to remove the gasket it would be helpful.
Thank you all.
Thank you all.
A solvent like acetone, available home depot, often removes much of a gasket, by dissolving what is causing it to stick.
You can get plastic scrapers from harbor freight, which definitely won't scratch metal. Letting the solvent soak a good long while, rhen scraping, often works well for such gaskets.
Youbare correct, DBW cars do not have an iacv (the ecu just controls butterfly to achieve same result).
Thank you!
Thank you!
clio (05-24-2021)
Personally I had made a list in February 2019 of things to check and maintain before joining the Forum. That list was composed using the following as a guide, which also led me to S2ki Forum:
S2000.club - Learnings and Tips
#88 reads: Clean your throttle body, MAP sensor, and MAP sensor tunnel regularly to combat confused ECU A/F ratios and the dreaded bucking / stalling / hesitation problem. Don't forget to Shin-Etsu the MAP sensor O-ring.
I admit postponing some items on the list and as stated above, after seeing the dirty TB my OCD must have kicked in. Lol! Being old school, my Grandfather taught me that lubrication was the life of you machinery. I learned to drive and maintain equipment on an old Ford tractor as a child.
Using the Service Manual section 11-499, page 795 I followed Honda’s document.
Maybe I should leave well enough alone, I realize the ECU compensates for build up on the TB. Old habits of keeping an intake clean are hard to break!?!
Thanks for the support!
