Question about rebuilding ap1 block and boring
Will it benefit me to increase cylinder size and get bigger pistons to make it a 2.2 vs 2.0? I have a loud knock when I start the car and it gets louder with throtle. I figure I have bearing problem at the least. What would you guys do if you were rebuilding? I might go FI in the future.
You can't just bore it oversize (much). The FRM (Fiber Reinforced Metal) cylinder lining is very thin, about .02 I think. You could sleeve it out some significant amount - I don't know exactly how much.
The AP2 gets its 2.2 liters by stroking, not boring. That's why the rev limit gets lowered to 8000 rpm.
Originally Posted by driftintherain,Dec 5 2007, 12:59 PM
if i were in your situation... i think i'll just port and polish the head...
Originally Posted by nsxracer,Dec 5 2007, 09:41 PM
but its the bottom end thats went bad...
http://www.youtube.com/watch?v=dyBllnMZaLE
If it does, you scored a bore. If it is your bearing, stop driving it now, and you might be able to salvage your crank etc...
You can't re-finish the block if your scoured a bore, you will need to re-sleeve, or get a new bottom end!
lookinco
10-15-2010 03:51 AM
