Question about rear differential removal?
I was wondering if it is necessary to pop the lower ball joint when removing the rear differential. Is there any other way to do it because i don't have a ball joint popper. does anyone have a link for this install i tried searching but couldn't come up with anything. any help is appreciated.
They're all in the FAQ's:
https://www.s2ki.com/forums/index.php?showtopic=108435
You don't "have" to if you can shift the whole diff to one side about an inch to get the centering pin on the half shaft out. This requires that you unmount the diff first and support it in some way so that it can be moved from side to side.
Originally Posted by 00SpaYellow,Jun 21 2005, 10:58 AM
could i unbolt the upper control arm and get the space i need from there.
bgoetz
02-03-2017 08:02 PM
ItalianBucwheat
09-27-2003 08:47 AM
