question about my tranny
So yesterday it was very hot. Maybe around 90 degrees. I was spirt driving my car for about 5 mins. Meaning I was flooring it around some turns and twist. Well after I stopped I noticed my car would not go into 1st and 2nd gear.. sometimes into 2 if I pushed hard and gave it some gass. I got the car home and turned it on today and it felt fine. Maybe alittle ruffer then normal sometimes.. what do you think may be wrong? Maybe the fluid got to hot? Or low on fluid? I have a 05 with 29k miles
Temperature could break down MTF fluid but it's not going to do that in five minute hard driving in 90 degree weather(which is NOT that hot to be honest)
do you have a leak in the drive train?
we wouldn't know the fluid level on your car so please look for previous service record and such..lol
hard to engage into gear could be a number of thing, low/old MTF fluid, dry shifter tunnel, leaky mc/sc on the clutch system(not engaging all the way)
Hmm I don't think anything is ealking because I never notice anything on the ground so I don't think that is the issue. I think I just need to change my fluid .. how often do you need to change it?
I just did mine and it shifts a little better. I used Redline MT90 for the trans & Mobile 75w90 LS for the diff
I dont know if its normal, but now its a little hard to shift into gear until the car is warmed up. Might be the Redline, but Ive used it on other cars no problem. Maybe next time Ill try the Honda fluid.
so it's from 6k to 9K for trans and diff
not a single issue at 130k
