question about koni yellow install
do i have to redrill the dust cap, and a couple of metal washers? also, do i use a 1/2 drill bit? what is the easiest way? any one have any tips?
You do have to do some drilling. If you call Koni, they will fax you the installation instructions. The instructions tell you what to drill and what size to drill them.
-Pete
-Pete
do i need to rethread the shocks bottom bolt? i tried to see if the bolt would just screw right on but it wouldnt, im scared to get the bolts stripped in there.
