Question about brake fluid
Hi guys, what the heck is the difference between DOT 4 and DOT 5 brake fluid... Never been into brake mods until now. ![smile.gif](https://www.s2ki.com/forums/images/smilies/smile.gif)
I just bought some DOT 5.1 motul brake fluid for my CRX, I still don't know what the heck this all means.
Thanks for your help.
i much much of a brake guy myself....but the "DOT"'s are somewhat of a rating system. the higher the number the higher the boiling point of the brake fluid, for racing situations etc. DOT 3 is what Honda Brake fluid is. I know that you can mix DOT 3 and DOT 4 brake fluid. But i believe DOT 5 is made up of a silicone base and SHOULD NOT BE MIXED WITH ANY OTHER TYPE OF BRAKE FLUID WHAT-SO-EVER!! Hope this helps??
Unfortunately DOT sucks at assigning designations. The DOT 5 is silicone and not compatible with other fluids, but DOT 5.1 is the latest synthetic which is compatible with DOT 3 & 4. Some vendors sell it as Improved DOT 4 just to avoid this confusion.
Will work great.. it is the best choice for a car that is driven.
Same goes for everyone. Thank you.
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Chris - Are you still using Valvoline Synpower (DOT 3 & 4)? I've not noticed DOT 5.1 fluid at the local Discount Auto parts - is it only sold at specialty stores?
BTW, the stiffer Comptech front bar is the best thing that I've done to the car - I can now understand why there are so many people that raved about the Mugen bar.
No, the Synpower stuff worked ok (still used in the wife's car), but I found a deal on the Neo fluid, and I buy Motul when I get pads since Carbotech discounts it with a purchase. Both have higher dry boiling point so maybe I can skip the end of track day bleed often needed.
Yes, I think the larger front bar is an improvement but there have been some that do not like it.
