Question about ABS
Question about ABS
I was unpluged ABS bump for couple track session, and pluged it back the next day, but ABS light still there and ABS not working. Like SRS light you have to bypass the pins. I know normally if it's good the light should be gone after few mins driving, but is there anything I have to do for ABS?
Generic OBDII scanners can't get an ABS code. Take it to a dealer to get the codes pulled is probably the easiest way.
Otherwise you'd have to jump the SCS pins in the DLC connector and count the flash code. (which can be a PITA if you are not mechanically inclined)
