Q - installing vafc + harness with esm
Originally posted by RT
PM the guy you got that diagram from and ask him how it worked.............
Zero'd out V-AFC has the VTEC set where?
I dont know where the vtec is set on new vafc
....... in that case, can you post a link to the thread it came from?
In that thread, he had two versions of that diagram, one right and one wrong. Which ever one I said was right in that thread is the correct hook-up.
............ as far as the VTEC point on the new V-AFC is concerned, I don't know the default setting either, but you better not leave it there as part of your "zero'd out" state (better set the TPS range and sensor type too)
I think that thread only had one diagram, and I cant find it now, but you ok'd this diagram Im showing, so I will go with it
I guess my concern now is the vafc installed with no initial settings programmed.
