Putting in new pistion rings
So i did a leakdown and compression test and came up with 2 bad rings and a slightly bent valve... i ordered OEM rings today and i am gonna start pulling off the head soon... im taking the head to the machine shop to get it pressure tested etc. Do i simply replace the rings or do i have to do something called a hone? dont know what that is but i read about it a few times..
If you don't know what a hone is or when to use it, I wouldn't be trying to replace the rings myself. Find someone who has done this kind of work before and have them guide you or watch them do the work.
Location: 13851 A Better Way #11D, Garden Grove, CA 92843
1 Post
If you have two bad rings, you are most likely looking at a complete rebuild in the bottom end. Replacing rings and honing while the block is still inside the car, is what the automotive repair industry would call a half ass way to do it.
i see , so once the walls are exposed i can have a pro look at them and see if it will need any attention...if i have to pull out the motor to get better results then thats what i will do...i just didnt know what a hone actually was.
