pulling my engine
![](https://www.s2ki.com/forums/images/s2ki/ranks/gold_member.png)
i swung the alternator and got the top starter bolt, disconnected the engine harness from the ecu and fuse box. i disconnected the engine block ground and starter cable to the smaller fuse box, but do i need to completely remove the alternator before i pull the engine? are there any wires attached to the alternator that is still attached to the car?
thx
thx
there are two wires connected to the alternator, and the other ends go to the large wiring harness. although i did, i don't think you have to remove the alternator to pull the engine. if you do decide to remove it there are just two bolts that hold the alternator in place, its pretty simple to remove.
