pulling code
Old 11-19-2008, 08:04 PM
a_zepeda926's Avatar
Default pulling code
Tried searching but couldnt find anything about pulling a code with the engine on, and i dont mean with an ODB reader, as im trying to get my ABS code. I didnt think it would be a problem, but just want to make sure. The damn ABS light comes on intermittently and it always decides to do it when i want to run my a/c. for some reason when it comes on my a/c and fan turn off. So i want to try and catch it in the act of it coming on.
Old 11-20-2008, 07:13 PM
anybody?
Old 11-22-2008, 02:47 PM
Old 01-27-2009, 10:24 PM
just realized i never got an answer to this and my abs light still comes on every once in a while.
Old 01-28-2009, 06:59 AM
negcamber's Avatar
The error codes are stored in memory. You can use a paper clip to make a jumper between pin 9 to pin 4 on the OBDII port and watch the SRS flashes to get the codes. If you aren't comfortable with that, Honda has a reader that can pull the ABS codes that most generic OBDII readers won't.
Old 01-28-2009, 08:48 AM
i have an obd reader already, and would prefer not to purchase another one. and as for the storing of the codes, last time i tried to pull the abs code that keeps popping up, i got no codes, and i believe its because it usually turns off by the time i pull into the garage/turn the car off.. thats why i was questioning about trying to pull the code while the actual car is on so i can catch the code while the abs light is actually on.
Old 01-28-2009, 09:29 AM
negcamber's Avatar
Yeah...generic OBD readers usually won't work on the ABS codes. You would have to go to Honda...I doubt they would sell you their reader, but they would charge a fee to pull the ABS codes for you.
Old 01-28-2009, 01:50 PM
just curious as to why the paperclip method doesnt work? i thought it was supposed to work for all codes?
Old 01-28-2009, 04:49 PM
negcamber's Avatar
You can use the paperclip trick...but the way the ABS codes are stored is different...the most recent code overwrites the last one and can only be retrieved by the Honda reader.
Old 01-28-2009, 05:21 PM
so is it only safe to do the paperclip trick while the car is off though?
Quick Reply: pulling code
