Pulling the block
We used a 1" drive socket and 4 feet of leverage on both the holder and the socket. This wasn't so bad but it did take a tremendous amount of torque. Some have reported that it can take up to 500 lb/ft to crack that thing lose. Once you get it to move even 1/4 turn, you're home free.
Originally Posted by FF2Skip,Sep 15 2005, 05:53 PM
We've snapped a 1/2" breaker bar(picture later) trying to go CCW. I have a Comptech sc which doesn't really matter.
I'm becoming very frustrated. Any tips, suggestions, etc. are appreciated. The head has already been removed.
I've got a 3/4" drive ratchet you can borrow. It is only a Craftsman, but at least it wouldn't matter if it broke. It might be hefty enough to do the job, just stick a pipe on it if you need more leverage. I've also got a 1/2" drive breaker bar if you want to give another one a shot (craftsman as well unfortunately)
John
Originally Posted by billman250,Sep 15 2005, 08:29 PM
Question about your question
You trying to pull the motor/trans as a unit? Is that why you need to pull the crank pulley?
The 1/2" breaker bar we used was a old Craftsman one that was my dad's. I had a pipe over that. I had a blanket wadded up on the passenger side fender... just in case we got lucky. I'm thankful that Sharon Loving stopped by with Mike's holder a couple of weeks ago.
As frustrated as I am(it's been almost a year since PrincesS has been whole), I guess I should be very thankful that I have a home, garage, and family unlike many down south.
it is easier to have them both come out at the same time.. let me look how i did mine and i'll post it up the truth was i couldn't remember..... but your car hasa been apart for a year?
Whatever happened to the old run the breaker bar taught to the ground and use the starter motor to undo the bolt for you? Does that work? <never done it before on the S... just got some old V8 experience>
Originally Posted by billman250,Sep 15 2005, 06:35 PM
I'd say if you could fit a 3/4 drive it would be great, haven't tried it. I think it comes down to the strength of the 1/2 stuff...maybe a bud has something of high quality kicking around...
I wouldn't try it on a S though. The Starter is not cheap or easy to replace, the battery is under 500cca. I'd predict a heavy click from the solenoid, and that's about it.
Another S2ki member had his car on jackstands with the e-brake engaged. The starter didn't have enough power to spin the motor over with the brake on.
