Pulled out the magnetic oil drain bolt to these two little surprises...any ideas??
laserred02 (08-01-2017)
This guy pulled little pins like yours from his head. Turned out he broke a rocker, might have been the needle bearings on the roller rocker. You can see it starting at ~5:45
Here are the pictures of the VC removed
So last week I went ahead and removed the valve cover. I saw that there was no scoring/damage that I could feel with my fingertip. No pitting either. Does this help narrow things down at all?
This thread has me wondering if I would be better off without the Fumoto valve I have installed.
how many miles did you put on the cams? maybe you should inspect and take pics of your cam journal. Thats typically where your can see some wear. I have bc cams also so I'm curious this is a direct result
billman250 has a thread on aftermarket head cams self destructing. i highly suggest you check out that thread, and shoot him a PM.
