Pulled a code, let's talk about it...
Old 06-18-2006, 08:09 PM
xviper's Avatar
Originally Posted by Eluded,Jun 18 2006, 08:57 PM
Maybe its the MIL indication?
This is what we've been talking about this whole thread.
MIL = CEL = DTCs (or codes)
Old 06-18-2006, 08:14 PM
SenderGreen's Avatar
Originally Posted by Eluded,Jun 18 2006, 07:57 PM
Maybe its the MIL indication? Per my Haynes manual, P1456 (90) Evaporative Emissions (EVAP) Control System (see page 11,135) ?
Actually, if it is (90) it could be either P1456 or P1457.
Old 06-18-2006, 08:32 PM
fuzy24's Avatar
Yeah to be honest, I had a very hard time finding the exact one for 90. I knew it was EVAP related but couldnt find the exact one...I don't even know how I pinned it to that one lol.
Now onto serious things. No I haven't been driving thousands of miles. Yes it has been to work and back. ~500ish miles and I had (seemingly) gone through two quarts of oil. I put two quarts in two weeks ago because it was reading below low...which brought it to high, and then added another 2 quarts a couple days back when it was back to low again. Call me crazy, but this is how it has been. Like I said, no smoking or oil coming from the tail pipes. My first clue to all of this was that the car was running like crap 3 weeks ago, and I did the whole sensor whack with a screwdriver and things cleared up. The CEL came back, and thats when I pulled the code today.
So assuming it is EVAP related (i'll head up to autozone in the next day or two to make sure), what am I looking at? Is this oil usage related to that? Or should I be crying right now and looking for another engine/car......
Further, what would be a common fix for an EVAP problem?
Old 06-18-2006, 08:45 PM
Definitely not crying, hopefully not looking for a new engine/car either.
It could be something as simple as a loose gascap. I think there was a problem with the fuel filler neck on 02 and early 03 S2000's. It would still really depend on what your DTC is. I just noticed there is actually a TSB for P1457.
As far as oil consumption goes, I don't really know. How do you check it? Do you check it the same way everytime? That does seem like too much of a difference to be from checking it at different temps, but like I said I don't really know.
Old 06-18-2006, 09:21 PM
xviper's Avatar
2 qts in 500 miles is TERRIBLE! However, this type of consumption would result in a badly smoking exhaust or a big pool of oil under the car where you park. More investigation is necessary. I would suggest you do a HOT oil level check on level ground.
Ensure the engine has reached operating temps for some time. 1/2 hour to 1 hour continuous engine operation ought to do it. Stop on level ground, turn off engine and immediately pull out the dipstick. Wait about 3 minutes to allow for reasonable drain back, then shove the stick in and pull it out for a read.
You can also do a cold check. Checking oil level shouldn't be rocket science but it seems it's not always done right. I've posted about a way to get consistent reads here:
https://www.s2ki.com/forums/index.php?showt...dpost&p=3285584
jimi
04-18-2006 04:33 PM
jimi
04-18-2006 02:35 PM
jah
08-11-2005 09:05 PM
rhood
02-08-2005 04:12 PM
Empedocles99
01-11-2005 04:28 PM
Quick Reply: Pulled a code, let's talk about it...
