Puffing white smoke
Old 07-01-2013, 06:07 PM
Danwolski's Avatar
Originally Posted by realblag
Get one of the chemical test kits and check your coolant for combustion gasses. This is a quick and cheap way to check your head gasket.
Never heard of these, what exactly are they called?
Old 07-01-2013, 08:40 PM
realblag's Avatar
http://www.napaonline.com/Catalog/Ca...006_0361172686
Old 07-02-2013, 01:48 AM
INDYMAC's Avatar
Take an engine oil sample and send it in to a lab for analysis. Pay additional for glycol test. You will be looking for high sodium, potassium, or glycol readings in the oil. A good place to order a kit is Polaris Labs. Blackstone doesn't test for glycol, but uses Na and K to speculate coolant contamination. Good luck!
I would also send a clean sample of whatever oil you use to estabish a baseline for NA, K, and glycol for a more accurate interpretation of the UOA. Some blenders are starting to use DOW oil soluble PAG in their formula's, so glycol will show in the clean sample if they use it.
Old 07-02-2013, 06:36 AM
GravyRobber's Avatar
Are you 100% sure it isn't light blue (oil) smoke? It can be hard to tell a difference sometimes. Puffs of blue smoke would be fairly typical of an AP1.
s2cho
07-07-2011 11:07 AM
andiamos2k
09-28-2010 01:26 AM
S2SEXY
10-28-2005 08:46 AM
9kFever
08-24-2005 05:13 PM
Dolemike
08-08-2005 10:50 PM
Quick Reply: Puffing white smoke
