Prototype S2000 Header from Rick
Old 01-03-2005, 10:23 AM
  #131
Stratocaster's Avatar
Originally Posted by FF2Skip,Jan 3 2005, 01:21 PM
It appears the pulls were 2.5 hrs apart.
Exactly. That is how long it takes to cool the header off and get it swapped out. Also I will post a larger version of the Dyno.
Old 01-03-2005, 10:24 AM
  #132
Originally Posted by Ludedude,Jan 2 2005, 10:00 PM
If I read that correctly, you gained 3 HP and lost 3 lbs of torque?
Yes, you are reading it wrong.
There was a MAX HP loss of 3HP and MAX Torque gain of 4. but if you look at the graph, you will see that the HP and TQ numbers are up along the whole chart. HP drops at over 7.5k and then drops off faster then the OEM header. But the gains are there in the low and mid ranges.
Old 01-03-2005, 10:36 AM
  #133
Here is a larger version. The gallery software on S2ki.com onlonger support larger views.
Old 01-03-2005, 10:40 AM
  #134
Former Sponsor
Gernby's Avatar
Did you do any sort of fuel tuning before or after?
Old 01-03-2005, 10:41 AM
  #135
Nope, with what. The car is stock.
Old 01-03-2005, 10:59 AM
  #136
Administrator
Ludedude's Avatar
OK, I guess I was reading it backwards then.
Old 01-03-2005, 12:50 PM
  #137
CrazyPhuD's Avatar
Interesting nice midrange gains....still hard to see the details of the dyno and when I click on the dyno it doesn't expand for me(i.e. it lists as unavailable) Is the dyno in a private gallery?
As to the top end you may not really be losing that much. Hard to see from the curves, but considering all the variables involved 3hp is probably within the statistical error of the experiment. You'd have to run many more tests to know for sure.
Still it looks like nice mid-range gains and comparable top end performance. You should convince a local MY04 owner to come in and test it. Curious what it will do with the 2.2L.
Old 01-03-2005, 01:14 PM
  #138
gfacter's Avatar
Is this still going to sell for less then $ 800.00?
If so when do you expect to have them ready?
Old 01-03-2005, 01:18 PM
  #139
Yes, closer to 600 then 800. At least for the first GB, and then we will see.
Click here for a larger DNYO chart Note: This one is HUGE
Old 01-03-2005, 01:24 PM
  #140
CrazyPhuD's Avatar
Thanks for the bigger dyno pic(and it is HUGE )...hmmmm interesting...so how does it feel when driving?
Quick Reply: Prototype S2000 Header from Rick
